11 years ago
Why my Nios II run slowly ?
Dear all,
I have do experiment on the Cyclone V SOC. [Helio evaluation board]
And I put one nios/e and onchip-ram into the FPGA fabric.
Currently, I could read/write the data in/out from Onchip RAM.
Now, I am measuring the time duration for my source code.
I discover that each instruction runs slowly.
Below is my simple source code.
I don't understand that the one line[*pdata = i++;] I comment , it needs to take 1us.
It should not be correct performance.
Or should I choose the better version of Nios II ?
Anyone could suggest or hint me why and what to do?
Attached file is my zip file of QSYS.
# include <stdio.h># include "system.h"# include "altera_avalon_pio_regs.h"
unsigned int LED_TOGGLE = 0;
unsigned char *pData = ONCHIP_MEMORY2_1_BASE;
int main()
int i = 0;
printf("Hello from Nios II!\n");
while(1)
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,LED_TOGGLE);
LED_TOGGLE = ~LED_TOGGLE;
//*pdata = i++;
return 0;
    Use NIOS /f and compile without debug information and with optimizations
    Hi, I use scope[logic analysis] and connect the LED output.
    And comment / dis-comment the line of [write data]. check time difference between comment and dis-comment.
    What is your clock speed ?
    I presume much faster than 1MHz.
    According to my QSYS,
    All components[including NiosII] are connected to clk and it is default for 50Mhz.
    Count the instructions in the loop:
    1) Read of LED_TOGGLE for the io_write
    2) Write of LED_TOGGLE to the hardware
    3) Read of LED_TOGGLE for the invert
    4) the invert inself
    5) Write back of LED_TOGGLE
    6) Unconditional branch
    IIRC a nios/e takes 5 clocks per instruction - so that is at least 30 clocks.
    The constant LED_PIO_DATA_BASE might also be created each loop iteration.
    Add in any extra clocks for the avalon write caused by your slave itself.
    Make LED_TOGGLE a local variable (so it can be assigned to a register).
    Compile with -O2 so that the compiler moves some calculations outside the loop.
    That should get you to a three instruction loop.
    Thanks for all suggestion.
    Because my Quartus II/NiosEDS is web edition, some option does not appear like optimization and version of Nios.
    I select subscription edition of Quartus, choose Nios/F and select opt to O2 or O3.
    It seems to get better performance.
    Thanks a lot for everyone.
    actually, i am still wondering what do toy mean by slowly..
