20 years agoWhy is sending tcp so much slower than receiving?
I have some code running under uC-OS that receives a file via TCP and then writes it to flash. This is very quick, a 4MB file is received in 20 seconds or so. I then have another piece of code that d...
20 years ago --- Quote Start --- originally posted by bkucera@Jul 26 2006, 03:56 PM i am using uc-osii, yes. no particular reason to use the raw api, just seemed easiest to do it this way. i haven't tried profiling it because i don't know how. i did monitor the traffic with ethereal and didn't see anything odd, but i'll look at it again and post back with what i find.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17154)
--- quote end ---
--- Quote End --- I don't think that using the raw API is tested in combination with uC-OSII. I'd advise trying the sockets based API, as it is supported. The raw API is intended for single-threaded systems. Cheers, - slacker
