20 years ago
why has two compilers
Hi hippo.
in staging_dir , It has nios2-linux-gcc and nios2-linux-uclibc-gcc,Why?
Could you tell me which is the default apps's library?
1 Reply
    --- Quote Start ---
    originally posted by zzh@May 25 2006, 11:08 AM
    hi hippo.
    in staging_dir , it has nios2-linux-gcc and nios2-linux-uclibc-gcc,why?
    could you tell me which is the default apps's library?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15563)
    --- quote end ---
    --- Quote End ---
    nios2-linux-gcc is a symbolic link (similar to short cut in Windows) , pointed to the real nios2-linux-uclibc-gcc.
    The default apps library is uClibc&#39;s libc, so you don&#39;t need -lc .
    If you use math, you need -lm .
    If you use pthread, you need -lpthread .
    If you use crypt, you need -lcrypt .
    .....etc.
    You will need those include headers, too.
    The order of librarys is important, the linker will search only one pass by default.
    The default include dir search path is staging_dir/include .
    The default library search path is staging_dir/lib .
