22 years agoWhy has the CF-Interface its own bus?
Hello, Why has the CF-Interface its own “Avalon Tri-State Bridge”? Isn’t it possible to connect the CF-Interface to the “Avalon Tri-State Bridge” of the ext_ram_bus for saving some IO-Pins? Whi...
22 years agoHello Dennis,
Thank you for your reply. I forgot to explain that I consider sharing the CF-Signals with the ext_ram_bus in a new design and not with the development board (sure that’s not possible). So it is possible to save some IOs in a new design. I hope there’s no timing problem when handling data from the Ethernet controller and the CF. Bye, niosIIuser
