19 years agoWhy does ROMRAM ECOS not initialize ICache of NIOS
Please refer to NIOS II vector.s file. Why does NIOS II ROMRAM application not initialize NIOS II I-Cache?
/* * ======================================================================== * _hardware_reset * * This is the reset entry point for Nios II. * * At reset, only the cache line which contain the reset vector is * initialized. Therefore the code within the first cache line is required * to initialize the instruction cache for the remainder of the code. * * Note that the automatically generated linker script requires that * the .init section is less than 0x20 bytes long. */ .section .entry, "xa" .align 2 /* * Some tools want to know where the reset vector is. */ .globl _hardware_reset /* * Explicitly allow the use of r1 (the assembler temporary register) * within this code. This register is normally reserved for the use of * the compiler. */ .set noat # ifdef CYG_HAL_STARTUP_ROM _hardware_reset: /* Initialize all cache lines within the instruction cache */ # if NIOS2_ICACHE_SIZE > 0 /* * The assumption here is that the instruction cache size is always * a power of two. */ # if NIOS2_ICACHE_SIZE > 0x8000 movhi r1, %hi(NIOS2_ICACHE_SIZE)# else movui r1, NIOS2_ICACHE_SIZE# endif movui r2, NIOS2_ICACHE_LINE_SIZE 0: initi r1 sub r1, r1, r2 bgt r1, zero, 0b# endif /* NIOS2_ICACHE_SIZE > 0 */ /* * Having initialised the cache, call the entry point for the .text * section. */ movhi r1, %hiadj(_start) addi r1, r1, %lo(_start) jmp r1# endif /* CYG_HAL_STARTUP_ROM */No RepliesBe the first to reply
