13 years agoWhy does NIOS write redundant stuff to SDRAM?
Hi, I have built a system with PCIe-NIOS-SDRAM, with the program being stored in a separate onchip memory. I am able to read and write data to SDRAM through PCIe, And also able to read and wr...
13 years agoIt sounds like your BSP linker script is not set correctly to only use the onchip memory. Check it in the BSP editor.
