16 years agowhy cann't boot uclinux from sd card
hi all,
After,I mounted sd card over spi successfull,I followed the root device topic(http://www.nioswiki.com/operatingsystems/uclinux/rootdevice), step by step ,but cann't boot from sd card. and always show the message as test1: ==================================================== VFS: Cannot open root device "mmcblk0p1 rw rootfstype=jffs2" or unknown-block(0, 0) Please append a correct "root=" boot option; here are the available partitions: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) uClinux/Nios II Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032 Kernel command line: root=/dev/mmcblk0 rw rootfstype=jffs2 PID hash table entries: 32 (order: 5, 128 bytes) Dentry cache hash table entries: 1024 (order: 0, 4096 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 5816k/2095k RAM, 0k/0k ROM (1791k kernel code, 304k data) Mount-cache hash table entries: 512 net_namespace: 180 bytes NET: Registered protocol family 16 NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 512 (order: 0, 4096 bytes) TCP bind hash table entries: 512 (order: -1, 2048 bytes) TCP: Hash tables configured (established 512 bind 512) TCP reno registered NET: Registered protocol family 1 io scheduler noop registered io scheduler deadline registered (default) ttyJ0 at MMIO 0x19020a0 (irq = 1) is a Altera JTAG UART console [ttyJ0] enabled ttyS0 at MMIO 0x1902000 (irq = 2) is a Altera UART dm9000 Ethernet Driver, V1.30 mmc_spi spi2.0: ASSUMING SPI bus stays unshared! mmc_spi spi2.0: ASSUMING 3.2-3.4 V slot power mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. VFS: Cannot open root device "mmcblk0" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ==================================================== test2: ==================================================== VFS: Cannot open root device "mmcblk0p1" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ==================================================== test3: ==================================================== VFS: Cannot open root device "mmcblk0" or unknown-block(0,0) Please append a correct "root=" boot option; here are the available partitions: Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ==================================================== and the kernel command line is "root=/dev/mmcblk0p1 rw",or "root=/dev/mmcblk0 rw", Are there anybody can tell me ,what should I do? THX!No RepliesBe the first to reply
