20 years agowhy can not use main() in my board?
hi, I am a beginer of niosII.why can i only use alt_main() in my custom board,if i use main() always failure.but i can use main() in my development board.what's the reason? thank you!
20 years agothis is my program:
# include "stdio.h"# include "alt_types.h"# include "io.h"# include "system.h"# include "string.h"# include "altera_avalon_uart_regs.h"# include "sys/alt_flash.h"# include "sys/alt_sys_init.h"# include "sys/alt_flash_dev.h"# include "altera_avalon_cfi_flash.h"# define BUF_SIZE 10 ////int alt_main(void) int main (void) { flash_region* regions; alt_flash_fd* fd; int i; int number_of_regions; int ret_code; alt_u8 source[BUF_SIZE]; alt_u8 dest[BUF_SIZE]; /* Set write_data to all 0x0 */ memset(source, 0x0, BUF_SIZE); memset(dest, 0x0, BUF_SIZE); i=0; for(i=0;i<10;i++) { *(source + i) =i ;} fd = alt_flash_open_dev("/dev/ext_flash"); if (fd) { ret_code = alt_get_flash_info(fd, ®ions, &number_of_regions); if (number_of_regions && (regions->offset == 0)) { /* Erase the first block */ ret_code = alt_erase_flash_block(fd, regions->offset, regions->block_size); if (!ret_code) { /* * Write BUF_SIZE bytes from write_data 100 bytes into * the first block of the flash */ ret_code = alt_write_flash_block( fd, regions->offset, regions->offset+0x00, source, BUF_SIZE);} if(!ret_code) {ret_code = alt_read_flash(fd, regions->offset, dest, BUF_SIZE);} }} i=0; for(i=0;i<10;i++) {IOWR_ALTERA_AVALON_UART_TXDATA(UART1_BASE,*(dest+i));} return 0;} \\\I have debug in my development board ,it has no mistake. ////this is some settings in system.h: /* * system configuration * */ # define ALT_SYSTEM_NAME "niossr"# define ALT_CPU_NAME "cpu"# define ALT_CPU_ARCHITECTURE "altera_nios2"# define ALT_DEVICE_FAMILY "CYCLONE"# define MY_NIOSIIS# define ALT_STDIN "/dev/jtag_uart"# define ALT_STDOUT "/dev/jtag_uart"# define ALT_STDERR "/dev/jtag_uart"# define ALT_CPU_FREQ 50000000# define ALT_IRQ_BASE NULL /* * processor configuration * */ # define NIOS2_CPU_IMPLEMENTATION "small" # define NIOS2_ICACHE_SIZE 4096# define NIOS2_DCACHE_SIZE 0# define NIOS2_ICACHE_LINE_SIZE 32# define NIOS2_ICACHE_LINE_SIZE_LOG2 5# define NIOS2_DCACHE_LINE_SIZE 0# define NIOS2_DCACHE_LINE_SIZE_LOG2 0# define NIOS2_FLUSHDA_SUPPORTED # define NIOS2_EXCEPTION_ADDR 0x00800020# define NIOS2_RESET_ADDR 0x00881800 # define NIOS2_HAS_DEBUG_STUB # define NIOS2_CPU_ID_SIZE 1# define NIOS2_CPU_ID_VALUE 0 /* * A define for each class of peripheral * */ # define __ALTERA_AVALON_TRI_STATE_BRIDGE# define __ALTERA_AVALON_CFI_FLASH# define __GENERIC_AVALON_SRAM# define __ALTERA_AVALON_JTAG_UART# define __ALTERA_AVALON_EPCS_FLASH_CONTROLLER# define __ALTERA_AVALON_ONCHIP_MEMORY2# define __ALTERA_AVALON_UART# define __ALTERA_AVALON_PIO# define __ALTERA_AVALON_SYSID /* * tri_state_bridge configuration * */ # define TRI_STATE_BRIDGE_NAME "/dev/tri_state_bridge"# define TRI_STATE_BRIDGE_TYPE "altera_avalon_tri_state_bridge" /* * ext_flash configuration * */ # define EXT_FLASH_NAME "/dev/ext_flash"# define EXT_FLASH_TYPE "altera_avalon_cfi_flash"# define EXT_FLASH_BASE 0x00000000# define EXT_FLASH_SETUP_VALUE 40# define EXT_FLASH_WAIT_VALUE 160# define EXT_FLASH_HOLD_VALUE 40# define EXT_FLASH_TIMING_UNITS "ns"# define EXT_FLASH_UNIT_MULTIPLIER 1# define EXT_FLASH_SIZE 8388608 /* * sram configuration * */ # define SRAM_NAME "/dev/sram"# define SRAM_TYPE "generic_avalon_sram"# define SRAM_BASE 0x00800000 /* * system library configuration * */ # define ALT_MAX_FD 32# define ALT_SYS_CLK none# define ALT_TIMESTAMP_CLK none /* * Devices associated with code sections. * */ # define ALT_TEXT_DEVICE SRAM# define ALT_RODATA_DEVICE SRAM# define ALT_RWDATA_DEVICE SRAM# define ALT_EXCEPTIONS_DEVICE SRAM# define ALT_RESET_DEVICE EPCS_CONTROLLER
