21 years agoWhy can not set Program memory to FLASH
I make a simple SOPC Builder system with only EPCS+onchip ram and without other offchip Flash and sram/sdram. I test it under Nios II IDE that it does work when program memory(.text) and read-only da...
21 years ago --- Quote Start --- originally posted by seu_xugh@Sep 1 2005, 09:53 PM i make a simple sopc builder system with only epcs+onchip ram and without other offchip flash and sram/sdram. i test it under nios ii ide that it does work when program memory(.text) and read-only data memory(.rodata) are set to onchip ram.
but when i try to set .text and .rodata to epcs under system library properties, the program can not be downloaded to the board, displaying the following message: leaving target processor paused.
why can not set these read-only program or data to flash? --- Quote End --- Oh you certainly can But Download to Board does not work with Flash If you want to download the code into flash, use the flash programmer. regards Pavan
