19 years agowho can help me?
I'm a newbie,and I want to port the uClinux to my board,which is GW48.My board's FPGA is EP1C6Q240C8,it has two CY7C1041 SRAM,and a SST 39VF160 Flash.Can anyone tell me whether it can success or give me the suggestion?
--- Quote Start --- originally posted by young@Oct 29 2006, 12:00 PM i'm a newbie,and i want to port the uclinux to my board,which is gw48.my board's fpga is ep1c6q240c8,it has two cy7c1041 sram,and a sst 39vf160 flash.can anyone tell me whether it can success or give me the suggestion?<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18984)
--- quote end ---
--- Quote End --- Your memory is too small to run uClinux. You should have at least 8MB SDRAM.
--- Quote Start --- originally posted by hippo+oct 29 2006, 05:39 pm--><div class='quotetop'>quote (hippo @ oct 29 2006, 05:39 pm)</div>--- quote start ---
<!--quotebegin-young@Oct 29 2006, 12:00 PM i'm a newbie,and i want to port the uclinux to my board,which is gw48.my board's fpga is ep1c6q240c8,it has two cy7c1041 sram,and a sst 39vf160 flash.can anyone tell me whether it can success or give me the suggestion?
--- quote end ---
--- Quote End --- Your memory is too small to run uClinux. You should have at least 8MB SDRAM. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=18989)</div> [/b] --- Quote End --- hippo,thank you for reply! Do you mean that I can't port the uClinux to my board in any way?
TO_BE_DONE
