20 years agowho can help me save my memory?
hello! I explant my uclinux system form arm(Samsung 4510) to nios2, I need build ppp with serial port, so we need pppd, now I have a terrible problem,I find the pppd consume neraly 1.2M sdram...
20 years ago"cat maps" print nothing,the directory /proc/(pppd pid) is as following:
arm platform:# cat maps# ls -l -r--r--r-- 1 root 0 0 Mar 13 10:13 mounts lrwxrwxrwx 1 root 0 0 Mar 13 10:13 exels: ls:./exe: No such file or directory lrwxrwxrwx 1 root 0 0 Mar 13 10:13 root -> / lrwxrwxrwx 1 root 0 0 Mar 13 10:13 cwd -> / -rw------- 1 root 0 0 Mar 13 10:13 mem -r--r--r-- 1 root 0 0 Mar 13 10:13 maps -r--r--r-- 1 root 0 0 Mar 13 10:13 statm -r--r--r-- 1 root 0 0 Mar 13 10:13 stat -r--r--r-- 1 root 0 0 Mar 13 10:13 cmdline -r--r--r-- 1 root 0 0 Mar 13 10:13 status -r-------- 1 root 0 0 Mar 13 10:13 environ dr-x------ 2 root 0 0 Mar 13 10:13 fd nios2 flatform:# cat maps# ls -l -r-------- 1 root root 0 Nov 30 00:01 auxv -r--r--r-- 1 root root 0 Nov 30 00:00 cmdline lrwxrwxrwx 1 root root 0 Nov 30 00:01 cwd -> / -r-------- 1 root root 0 Nov 30 00:01 environ lrwxrwxrwx 1 root root 0 Nov 30 00:01 exels: ./exe: No such f le or directory dr-x------ 2 root root 0 Nov 30 00:01 fd -r--r--r-- 1 root root 0 Nov 30 00:01 maps -rw------- 1 root root 0 Nov 30 00:01 mem -r--r--r-- 1 root root 0 Nov 30 00:01 mounts -rw-r--r-- 1 root root 0 Nov 30 00:01 oom_adj -r--r--r-- 1 root root 0 Nov 30 00:01 oom_score lrwxrwxrwx 1 root root 0 Nov 30 00:01 root -> / -r--r--r-- 1 root root 0 Nov 30 00:00 stat -r--r--r-- 1 root root 0 Nov 30 00:01 statm -r--r--r-- 1 root root 0 Nov 30 00:01 status dr-xr-xr-x 3 root root 0 Nov 30 00:01 task
