20 years agowho can help me save my memory?
hello! I explant my uclinux system form arm(Samsung 4510) to nios2, I need build ppp with serial port, so we need pppd, now I have a terrible problem,I find the pppd consume neraly 1.2M sdram...
20 years agoHello, Hippo!
I use the XXXX-flthdr in both of the platforms,the display is as follow: <div class='quotetop'>QUOTE </div> --- Quote Start --- In nios2 platform:[/b] --- Quote End --- [nios2linux@localhost pppd]$ nios2-elf-flthdr pppd pppd Magic: bFLT Rev: 4 Build Date: Mon Mar 6 17:02:53 2006 Entry: 0x44 Data Start: 0x23c30 Data End: 0x2adf8 BSS End: 0x46d4c Stack Size: 0x1000 Reloc Start: 0x2adf8 Reloc Count: 0x1130 Flags: 0x1 ( Load-to-Ram ) <div class='quotetop'>QUOTE </div> --- Quote Start --- In arm platform:[/b] --- Quote End --- [root@localhost pppd]# arm-elf-flthdr pppd pppd Magic: bFLT Rev: 4 Build Date: Tue Jul 20 16:25:09 2004 Entry: 0x50 Data Start: 0x24c60 Data End: 0x2b820 BSS End: 0x359e0 Stack Size: 0x2000 Reloc Start: 0x2b820 Reloc Count: 0xa2e Flags: 0x1 ( Load-to-Ram ) what do you find? Thanks.
