19 years agowho can help look at this problem?
Error: Symbolic name "extclkena3" must be port of megafunction, macrofunction, primitive, or state machine "pll" Warning: Symbolic name "extclkena" is used but not defined as a group -- attempted to use existing nodes Error: Symbolic name "extclkena2" must be port of megafunction, macrofunction, primitive, or state machine "pll" Warning: Symbolic name "extclkena" is used but not defined as a group -- attempted to use existing nodes Error: Symbolic name "extclkena1" must be port of megafunction, macrofunction, primitive, or state machine "pll" Warning: Symbolic name "extclkena" is used but not defined as a group -- attempted to use existing nodes Error: Symbolic name "extclkena0" must be port of megafunction, macrofunction, primitive, or state machine "pll" Error: Can't elaborate user hierarchy "nios2_sys:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component" Error: Quartus II Analysis & Synthesis was unsuccessful. 5 errors, 30 warnings ******************************************************************** it seems be some problem on PLL,but i don't know how to solve it. by the way, i use a pll generate two clocks: sys_clk and sdram_clk, the sys_clk's phsae shift is 270 deg and the sdram_clk's phase shift is (270-60.75) deg. please help me. thanks! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif1 Reply
Have you tried to read the help about these messages yet? Paste them here will help others to understand your situation.
roughly readding this: <div class='quotetop'>QUOTE </div> --- Quote Start --- Error: Symbolic name "extclkena3" must be port of megafunction, macrofunction, primitive, or state machine "pll"[/b] --- Quote End --- I suspect the PLL outputl extclkena3 is somehow misaligned with you destination port. You can check them in RTL viewer. Wait for more detail.
