20 years agowhich include dir is our lib
I did what hippo say in the forum,and get buildroot , linux-2.6.x ,apps and uClinux-dist.
I copied a C source program and named it as mu.It is like:#include <stddef.h># include <stdio.h># include <unistd.h># include </home/melvin/buildroot/build_nios2/staging_dir/include/pthread.h>
void * process(void * arg)
int i;
fprintf(stderr, "Starting process %s\n", (char *) arg);
for (i = 0; i < 10000; i++) {
write(1, (char *) arg, 1);
return NULL;
int main(void)
int retcode;
pthread_t th_a, th_b;
void * retval;
retcode = pthread_create(&th_a, NULL, process, (void *) "a");
if (retcode != 0) fprintf(stderr, "create a failed %d\n", retcode);
else fprintf(stderr, "create a succeeded %d\n", retcode);
retcode = pthread_create(&th_b, NULL, process, (void *) "b");
if (retcode != 0) fprintf(stderr, "create b failed %d\n", retcode);
else fprintf(stderr, "create b succeeded %d\n", retcode);
retcode = pthread_join(th_a, &retval);
if (retcode != 0) fprintf(stderr, "join a failed %d\n", retcode);
else fprintf(stderr, "join a succeeded %d\n", retcode);
retcode = pthread_join(th_b, &retval);
if (retcode != 0) fprintf(stderr, "join b failed %d\n", retcode);
else fprintf(stderr, "join b succeeded %d\n", retcode);
return 0;
} then $ nios2-linux-uclibc-gcc mu.c -o mu -elf2flt -lm
mu.elf2flt(.text+0xe8): In function `main':
: undefined reference to `pthread_create'
mu.elf2flt(.text+0x144): In function `main':
mu.elf2flt(.text+0x190): In function `main':
: undefined reference to `pthread_join'
mu.elf2flt(.text+0x1dc): In function `main':
collect2: ld returned 1 exit status why? Can sb tell me where our app should be creat ed? And which include dir is our library?1 Reply
try
use# include <pthread.h> in your program. and add -lpthread to the compile command.
