20 years agoWhether I build a uclinux to De2 board successfull
...//some operations
Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.11-uc0 (root@darkstar) (gcc version 3.4.6)# 1 Sat May 6 07:27: 12 AKDT 2006 uClinux/Nios II Altera Nios II support © 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6952k/8192k RAM, 0k/0k ROM (705k kernel code, 418k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler deadline registered Freeing unused kernel memory: 340k freed (0xba000 - 0x10e000) init started: BusyBox v1.2.0-pre0 (2006.04.26-14:48+0000) multi-call binary These are strings displaying on my DOS prompt. I downloaded a zImage_de2_net and do the work following this forum. So,Whether I build a uclinux to De2 board successfully?? Thanks!!2 Replies
good. you have successfully RUN a prebuilt image on DE2 board.
next you need to setup a Linux PC or install coLinux to your XP, and follow step 2 and 3 in the wiki, to BUILD the kernel, http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux) - Altera_Forum
Thanks!
I will do the step 2-3 and give my operations.
