21 years agoWhere to find "Linux compatible Quartus project"
Hi, All Where to find "Nios II Linux compatible Quartus project" (I need full cpu core) I use "uClinux 2.6 Distribution v1.1" and nios development kit, thanks!
21 years agoJust program your design (SOF and program) to "user" flash, if what you mean by "autobooting" is having the system come up and start running software right away.
uCLinux will, by default, allow connection via one of the UARTs on the Dev. Board that you have. You can then use Minicom, or whatever else you want to log in and use your uCLinux, that you've programmed to flash. Cheers, - slacker
