9 years agoWhere setup compiler mode (e.g. -std=C99 or -std=C11)
Hello, Where is location in Eclipse NIOS II settings, where compiler mode can be set. For example I want to change for more advanced mode (c99 or c11) in order to allow internal loop variable...
9 years ago --- Quote Start --- Below are the basic steps for the IPOPT compilation that should work on most systems. For special compilations and for some troubleshooting see Appendix 2.9 and consult the generic COIN-OR help page https://projects.coin-or.org/coinhelp before submitting a ticket or sending a message to the mailing list .... --- Quote End --- Are you sure you aren't mistaken with thread ? The question was on how to set compiler options for nios2-elf-g++ compiler that is part of "Nios II Software Build Tools for Eclipse". The last one contain already all necessary tools for generating code for nios ii softprocessor. What do you mean exactly ? Abandon "Nios II Software Build Tools for Eclipse" and use 3rd part tools ?
