16 years agoWhere is nios2-download?
I following the wiki: http://www.nioswiki.com/operatingsystems/uclinux/uclinuxdist I installed the binary toolchain and changed my PATH accordingly. But I cannot find the command nios2-download. ...
16 years ago --- Quote Start --- Does this imply that my linux system boots only after I run nios2-terminal? --- Quote End --- Yes, I think that's the default behavior. You should be able to change that behavior via a menuconfig setting, but I don't recall exactly what the setting is...sorry. Cheers, - slacker
