RPind1
7 years agoWhere is a reference design (with mSGDMA's) that works with the SSS EDS Template.
I can't seem to find any reference designs (Qsys files) that will work out of the box with the Simple Socket Server examples. Mainly because they all use regular SGDMAs and not the modular SGDMA's...
SengKok_L_Intel
7 years agoHi,
The following links consist of the SSS example designs (for Arria 10 and Cyclone 10 LP) that use MSGDMA, where the default SSS template is required to do some minor modification to fit into the different hardware profiles. Please have a look at the following example design.
https://fpgacloud.intel.com/devstore/platform/17.1.0/Standard/nios-ii-simple-socket-server-for-c10-lp/
https://fpgacloud.intel.com/devstore/platform/17.1.0/Pro/arria-10-nios-ii-simple-socket-server-design-example/
Regards -SK
RPind1
7 years agoThank you, Looks like that will probably work. Will try to reply after I test it out.
