20 years agoWhere does the boot loader come from
Hello:
I've got a NIOS 2 running out of DRAM. So I plan to put the configuration into epcs (done) and put the application program into a FLASH (also done). I used elf2flash to create the srec filt that I loaded using a serial port bacause that's the way it will be done in the field. I ran elf2flash --verbose --log=log.txt --input-Project.elf --output-ProjectOut.srec --base=0x09000000 --end=0x09FFFFFF --reset=0x08000000 -flash=U23 --boot=boot_loader_cfi.srec All this ran OK and I found the boot_loader data infront of the applicatio code as expected. My question are: 1. Is this the proper boot loader to use. 2. The sof file does not use a cfi interface but the flash device works since I can store data and erase blocks. 3. My flash interface is 16 bits wide but the boot loader looks like it's working 8 bits at a time. 4. How can I create a custom bot loader? Thanks George
