21 years agoWhere does the boot loader come from
Hello: I've got a NIOS 2 running out of DRAM. So I plan to put the configuration into epcs (done) and put the application program into a FLASH (also done). I used elf2flash to creat...
21 years agoOK i've done that and it looks like a fine boot loader moving 8 bits at a time.
But is this the correct one to use? How do I/you/anyone know? Did that source generated the srec file of the same name? thanks george
