When workign with BSP on NIOS 2, Eclipse's tool hangs indefinately
Hi @David15,
Thank you for posting in Intel community forum and hope this message find you well.
Quick clarification, did you managed to open/create new bsp files in the BSP editor? And the hangs is after or before?
As for the screenshot of the error mention, is that happening within the BSP editor window?
Would suggest to try an alternative which is to generate the BSP via NIOS terminal command, just to check if there is anything potential issues with the project.
Warm regards.
BB
- DiBosco5 years ago
Try looking at this:
https://stackoverflow.com/questions/65240134/nios-ii-ide-unsuably-slow/65713986#65713986
Carefully follow the instructions that the reply indicates, including running Eclipse from the command line with --clean option. This helped a lot on Linux.
Welcome to a world of pain you never thought possible with Altera and Eclipse.
