mametarou963
3 years agoWhen compiling with Nios II SBT, the optimize option (-O2) causes it to stop working.
Hi.
I am currently developing on Nios II Cyclone 10, but when I add the optimization option, it stops working. Is there any possible cause for this?
Development environment is as follows: * FP...
mametarou963
3 years agoSorry for the delay.
I have tried many things and as a result the simplest sample code is as follows.
* The following source is executable
#pragma GCC optimize ("O0")
static void SampleFunction( )
IORD_16DIRECT( 0x3400000 , 12 );
* On the other hand, the following source is not executable.
(Specifically, if you place a breakpoint on `IORD_16DIRECT` in the debugger and step through it after stopping, it will fail.)
Since the entire compilation option is subject to -O2, -O0 is applied to the former source and -O2 to the latter source.
Is there any possible problem?
