22 years agoWhat's wrong with the nios-elf-ld ?
When I compile my program, some error happen.
[SOPC Builder]$ make nios-elf-ld -LC:/altera/quartus41/sopc_builder/bin/nios-gnupro/nios-elf/lib/m32 -LC:/altera/quartus41/sopc_builder/bin/nios-gnupro/lib/gcc-lib/nios-elf/2.9-nios -010801-20020710/m32 -L../lib -L./librtos32 -e _start -u _start -g -T C:/altera/ quartus41/sopc_builder/bin/excalibur.ld main.o Tasks.o --start-group -l rtos32 - l nios32 -l c -l m -l gcc --end-group -o main.out nios-elf-ld: cannot find -lc make: *** [main.out] Error 1 My makefile is writed like this: LIBS = --start-group -l rtos32 -l nios32 -l c -l m -l gcc --end-group GCC_OPTS = -g -m32 main.srec: main.out nios-elf-objcopy -O srec main.out main.srec main.out : $(OBJETS) nios-elf-ld $(LIBPATH) $(LD_OPTS) $(OBJETS) $(LIBS) -o main.out I don't know what's wrong and how to correct it. Who can help me?5 Replies
TO_BE_DONE
Hi, Kerri
Thank to your help. I think the paths in my makefile maybe wrong. The problem was heppend when I use Nios Development Kit 3.20 to "make",but now I use Nios 3.02 to make,there is no error. How strange it is ! - Altera_Forum
Hello woody,
I think your original problem was a missing path, rather than wrong one. The linker could not find "libc.a" because there was no path specified for it; there should have been a "-LC:/altera/quartus41/sopc_builder/bin/nios-gnupro/nios-elf/lib/m32" (or whatever is required to point to the appropriate libc.a, libg.a and libm.a) in your LIBPATH definition. It may be that v3.02 had this in the linker script (excalibur.ld) - it would look something like: SEARCH_DIR("/cygdrive/c/altera/quartus41/sopc_builder/bin/nios-gnupro/nios-elf/lib/m32"); Steve. - Altera_Forum
--- Quote Start --- originally posted by steve360@Aug 13 2004, 10:13 AM there should have been a "-lc:/altera/quartus41/sopc_builder/bin/nios-gnupro/nios-elf/lib/m32" (or whatever is required to point to the appropriate libc.a, libg.a and libm.a) --- Quote End --- This option did in fact appear in the command-line that woody gave in his post. Woody, is this the correct path? If you look in this directory is there a libc.a there? In my installation the files are at c:\altera\kits\nios\bin\nios-gnupro\nios-elf\lib\m32\. - Altera_Forum
<div class='quotetop'>QUOTE </div>
--- Quote Start --- This option did in fact appear in the command-line that woody gave in his post.[/b] --- Quote End --- Oops! Sorry. Then both paths are probably wrong. There are two paths that need specifying, one to libgcc.a and the other to libc.a, libg.a and libm.a
