22 years agoWhat's wrong with the Flash-programmer?
I use flash-programmer to download the sof+elf files to the EPCS4(ref=U13), the actual project is called dl900, and my own target board called dl900_200, I use mk_target_board command to create it; ...
22 years ago --- Quote Start --- originally posted by doleksy@Aug 12 2004, 07:34 PM i thought i had already posted about this problem. we are doing the same in our design. in fact, all we had to do was insert a pio and have the out put go to a virtual pin. that fixed everything. altera is aware of this problem and the fix because we were on the phone to them with our fae as we fixed it. --- Quote End --- I have read your post, so i know what you said, I have added a PIO to the niosCPU, but it doesn't work, until add a tri-state-bridge and a component can connect to that tri-state-bridge. It is seemed that the niosCPU need a tri-state-bridge, not a PIO.
