22 years agoWhat's wrong with the Flash-programmer?
I use flash-programmer to download the sof+elf files to the EPCS4(ref=U13), the actual project is called dl900, and my own target board called dl900_200, I use mk_target_board command to create it; ...
22 years agoThanks everyone.
I have find the answer. I only use EPCS4 to store the elf+sof, so when i made the target board, i didn't add the tri-state-bridge, and now i add a tri-state-bridge, a virtual flash-chip (maybe lan91c111 also can work, i haven't try it), dont make pin assignments for this virtual flash-chip, then rebuild the target board project, and my actual project, and in IDE rebuild the niosII project, then the flash-programmer is ok.
