22 years agoWhat's wrong with the Flash-programmer?
I use flash-programmer to download the sof+elf files to the EPCS4(ref=U13), the actual project is called dl900, and my own target board called dl900_200, I use mk_target_board command to create it; ...
22 years agoThe first thing that comes to mind is a cable issue that we've seen intermittently.
can you try restarting your machine, and re-powering your board. Then try again? If it still happens we can try to figure it out from there. I see it's a custom board. If you can send the project to us we can try modifying it to match a board we have.
