22 years agoWhat's wrong with the Flash-programmer?
I use flash-programmer to download the sof+elf files to the EPCS4(ref=U13), the actual project is called dl900, and my own target board called dl900_200, I use mk_target_board command to create it; ...
22 years agoanother messenge is here:
make: Entering directory `/cygdrive/e/mydoc/myPrj/.../v1/logic/software/hello_world_0/Debug' Aug 12, 2004 9:36:16 AM - (??) nios2-flash-programmer: Launching Quartus Programmer to download: E:/mydoc/myPrj/.../v1/logic/dl900_200/system/dl900_200.sof Pre-Reading 6KBytes of data from U13: |----.----+----.----| ********************* (0.75 sec). Aug 12, 2004 9:36:23 AM - (??) nios2-flash-programmer: Success. Zero bytes written to U13- (because device matched contents of epcs_controller_boot_rom.flash) Aug 12, 2004 9:36:23 AM - (??) nios2-flash-programmer: Flash programming complete WARNING: Default charset GBK not supported, using ISO-8859-1 instead sof2flash --flash=U13 --offset=0x00000000 --output=safe.flash --input=\"E:/mydoc/myPrj/.../v1/logic/dl900.sof\" --epcs Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert --device=EPCS4 --option=safe.opt E:/mydoc/myPrj/.../v1/logic/dl900.sof safe.pof Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Thu Aug 12 09:36:25 2004 Info: Elapsed time: 00:00:00 Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert safe.pof safe.rpd Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings Info: Processing ended: Thu Aug 12 09:36:25 2004 Info: Elapsed time: 00:00:00 WARNING: Default charset GBK not supported, using ISO-8859-1 instead nios2-flash-programmer --input=safe.flash --sof=`D:/quartus/sopc_builder/bin/find_sopc_component_dir dl900_200`/system/dl900_200.sof --device=1 "--cable='USB-Blaster [USB-0]'" --epcs --relocate Aug 12, 2004 9:36:27 AM - (??) nios2-flash-programmer: Launching Quartus Programmer to download: E:/mydoc/myPrj/.../v1/logic/dl900_200/system/dl900_200.sof Pre-Reading 186KBytes of data from U13: |----.----+----.----| ********************* (6.094 sec). Erasing 7 Sectors: |----.----+----.----| ********************* (6.328 sec). Writing 448KBytes : |----.----+----.----| ********************* (6.468 sec). Verifying 448KBytes of data: |----.----+----.----| ***Aug 12, 2004 9:36:54 AM - (??) nios2-flash-programmer: Verification failure after write. WARNING: Default charset GBK not supported, using ISO-8859-1 instead make: *** [epcs_controller_boot_rom_safe_configuration] Error 8 make: Leaving directory `/cygdrive/e/mydoc/myPrj/.../v1/logic/software/hello_world_0/Debug'
