16 years agoWhat's the general way to incorporate handwritten module with TSE ethernet?
Suppose we have handwritten IP module that continuously reads data from ADC, processes it and writes to some on-chip fifo. Now we want to send those data via Ethernet. I got impression the common w...
11 years agoHi,
Thanks for the reply. I just switched to SGMII instead of RGMII and managed to read out high level on bit 5 for Marvel. In both cases, I could see LED activity, duplex and 1G LED were on, but I assume the clocking is a bit more complex in the RGMII case, so maybe there was some problem there... Also I just figured out that due to the waitrequest signal I was able to read out the correct value only sometimes. When I was actually reading the value the reg_busy is low, so I know that the read out value is the one stored in the register... This explains why a lot of times I was reading out zeros, because I wasn't really reading... Now I will try by just configuring the MAC registers using Verilog and I hope it will work... Thanks anyway
