15 years agowhat's the difference between enable_reduced_device_drivers and enable_small_driver?
I am now using NIOS II Eclipse. In BSP editor, you can choose to tick "enable_reduced_device_drivers" in setting tab or choose to tick "enable_small_driver" in drivers tab. But I am not quite sure what's the difference for these two functions. Any help?
Thanks...1 Reply
You can select the setting in the BSP Editor settings tree panel on the lower left panel of the main tab, then on the lower right you can see a detailed description of any setting.
