11 years agoWhat's the difference between an Avalon MM Master and an Avalon MM Slave
I need to design an Avalon MM IP component that allows software running on the HPS of a Cyclone V FPGA to access an external comms chip and an SRAM chip. The comms chip has a memory mapped register s...
11 years agoA processor or DMA implements Avalon-MM Master interfaces.
A UART or GPIO peripheral implements Avalon-MM Slave interfaces. A master generates bus requests, while a slave receives those requests. You would want to implement an Avalon-MM Slave interface. Also, look into the bundled Tri-State bridge component.
