22 years agowhat wrong with my nios ide build
when i test a simple c/c++ programe with hello_led_0 but when i build ,two error appear ,the information is that: Error *** [obj/altera_avalon_sysid.o] Error 1 hello_led_0 Error *** [sy...
22 years agoI'm new to NIOS II and still getting used to things. But I think you can solve you're problem in the Run menu, by disabling the "Vailidate NIOS II System ID before download" and just not using the core at all (this isn't helpful if you actually do need it though).
On that subject what's the system ID useful for other then a time stamp? Does it get used by the OS as the CPU ID as well? (I'm more of a hardware guy so I'm a bit slow when it comes to OS programming).
