21 years agoWhat is wrong with uClinux boot?
Hello, When I port the uClinux to my cyclone board, there has something wrong. I do not know clearly where error occur, just paste the result. Please help me. Here is my HW/SW entironment....
21 years agoI have solved my problem.
It is because of the Flash Programming Design. But another problem comes. When I make the system with Nios II/s Core + SDRAM + SRAM + Flash + EPCS + Timer + PIO + JTAG-UART, I creat the kernel and filesystem, upload them. The uClinux can startup in the Nios II SDK Shell. When I add the OpenCores 10/100M MAC, reconfigure the kernel with the igor_mac support, rebuild the kernle and filesystem. Upload correctly. But when type nios2-terminal in the Nios II SDK Shell console, the screen display " nios2-terminal: .................................... nios2-terminal: starting in terminal mode (Control-C exits)" The cursor stay here, nothing appears in the screen. I do not know what is wrong. But without igor_mac, the system can run uClinux properly. I use Microtronix Cyclone Development Board. The OpenCores 10/100M Mac is the earliest version of Microtronix Provided(run under nios I and uClinux V1.0 with linux 2.4.17 kernel). Can guys help me? If it is because of the old Version of igor_mac, can someone give me the latest version of the igor_MAC? Just Paste here. Thank you very much. In addtion, If I use Custom Board, in uClinux Configure Kernel, Processor type and feature --> Platform , which platform shoud I use? Thank you.
