21 years agoWhat is wrong with my design?
Hello, I followed the Altera Hardware Example Design on my Microtronix Cyclone DevBoard. I have tested the LowCost Design, and every Software Example Designs(in the Design Support Matrix) can r...
21 years ago --- Quote Start --- originally posted by rugbybloke+feb 22 2005, 05:26 am--><div class='quotetop'>quote (rugbybloke @ feb 22 2005, 05:26 am)</div>
--- quote start ---
<!--quotebegin-roujesky@Feb 21 2005, 10:10 AM <div class='quotetop'>quote
--- quote end ---
--- quote start ---
"nios2-terminal: warning: the jtag cable you are using is not supported for nios
nios2-terminal: ii systems. you may experience intermittent jtag communication
nios2-terminal: failures with this cable. please use a usb blaster revision b
nios2-terminal: cable or another supported cable. please refer to the file
nios2-terminal: errata.txt included in the nios ii development kit documents
nios2-terminal: directory for more information. --- Quote End --- We get this error every time, and we are using USB Blaster, so I am not sure that this error message is not a 'red herring'. [/b] --- Quote End --- You can still get the error message if you have a Revision A USB Blaster, hence the warning advising you to use revision B. [/b] --- Quote End --- Not nescesarily, we use an USB Blaster revision B here, and always get this error/warning. Untill now it hasn't prevented us from doing anything though.
