21 years agoWhat is wrong with my design?
Hello, I followed the Altera Hardware Example Design on my Microtronix Cyclone DevBoard. I have tested the LowCost Design, and every Software Example Designs(in the Design Support Matrix) can r...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- "nios2-terminal: Warning: The JTAG cable you are using is not supported for Nios nios2-terminal: II systems. You may experience intermittent JTAG communication nios2-terminal: failures with this cable. Please use a USB Blaster revision B nios2-terminal: cable or another supported cable. Please refer to the file nios2-terminal: errata.txt included in the Nios II development kit documents nios2-terminal: directory for more information.[/b] --- Quote End --- We get this error every time, and we are using USB Blaster, so I am not sure that this error message is not a 'red herring'. What *Blaster are you using? Also, I agree with LiangYi that it is best to DEBUG the system. It could be that it is working, but messages/lights are flying by so fast they are not visible to the naked eye http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif Good luck!
