21 years agoWhat is wrong with my design?
Hello, I followed the Altera Hardware Example Design on my Microtronix Cyclone DevBoard. I have tested the LowCost Design, and every Software Example Designs(in the Design Support Matrix) can r...
21 years agoIt's probably best for you to try and debug the system instead of running it.
It it doesn't get to main then try stopping at alt_main and stepping through the code from there to find out what the problem is. The next step depends on whether you can do any debug at all. (The warning message is warning you about intermittent failures. ByteBlasterII should work most of the time, but its not guaranteed, hence the warning message).
