20 years agowhat is the romptr?!!
Microtronix Linux Extensions Version 1.4, Built June 20, 2005 ------------------------------------------------ make: Entering directory `/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x' no emulation specific options. Using /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x as source for kernel GEN /cygdrive/c/laji/ljker/build/Makefile CHK include/linux/version.h SPLIT include/linux/autoconf.h -> include/config/* CHK include/nios2_system.h HOSTCC scripts/basic/fixdep scripts/basic/.fixdep.d: done. HOSTCC scripts/basic/split-include scripts/basic/.split-include.d: done. HOSTCC scripts/basic/docproc scripts/basic/.docproc.d: done. HOSTCC scripts/mod/mk_elfconfig scripts/mod/.mk_elfconfig.d: done. MKELF scripts/mod/elfconfig.h HOSTCC scripts/mod/file2alias.o scripts/mod/.file2alias.o.d: done. HOSTCC scripts/mod/modpost.o scripts/mod/.modpost.o.d: done. HOSTCC scripts/mod/sumversion.o scripts/mod/.sumversion.o.d: done. HOSTLD scripts/mod/modpost HOSTCC scripts/kallsyms scripts/.kallsyms.d: done. make[2]: `arch/nios2nommu/kernel/asm-offsets.s' is up to date. CHK include/asm-nios2nommu/asm-offsets.h CHK include/linux/compile.h HOSTCC usr/gen_init_cpio usr/.gen_init_cpio.d: done. CHK usr/initramfs_list CPIO usr/initramfs_data.cpio GZIP usr/initramfs_data.cpio.gz AS usr/initramfs_data.o usr/.initramfs_data.o.d: done. LD usr/built-in.o CC arch/nios2nommu/kernel/setup.o arch/nios2nommu/kernel/.setup.o.d: done. LD arch/nios2nommu/kernel/built-in.o CC mm/nommu.o /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/mm/nommu.c: In function `do_mmap_pgoff': /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/mm/nommu.c:615: error: structure has no member named `romptr' /cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/mm/nommu.c:616: error: structure has no member named `romptr' make[2]: *** [mm/nommu.o] Error 1 make[1]: *** [mm] Error 2 make: *** [_all] Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'No RepliesBe the first to reply
