21 years agowhat is the problem boot using nfs?
I try to boot linux using nfs. I can successfully configure the ip of the board. The last three lines of the messages are as follows: VFS:Mounted root (nfs filesystem) freeing unused ker...
21 years agocloud,
I create the filesystem in CF card,you may try.And I use the Aletra'stratix 1s10 board.I can startup,can write,can read,but there is one problem that once execute *.exe file ,the uclinux is restarted.The manner that rely on ramdisk,I don't try. Tony,Zhu
