21 years agowhat is the problem boot using nfs?
I try to boot linux using nfs. I can successfully configure the ip of the board. The last three lines of the messages are as follows: VFS:Mounted root (nfs filesystem) freeing unused ker...
21 years ago --- Quote Start --- originally posted by zrycq@Oct 31 2004, 08:20 PM cloud,
i use the omni-nfs server v4.2 as the nfs server in windows2000.so i boot the system as nfs is successful.are you correct the kernel config as microtronix documents?
tony,zhu --- Quote End --- Thanks, I followed the instructions according to the document. It seems that the nfs has been succesfully mounted. And the system did try to get started from nfs system. I did not change all the files in the /dev directory. does that matter?
