21 years agowhat is the problem boot using nfs?
I try to boot linux using nfs. I can successfully configure the ip of the board. The last three lines of the messages are as follows: VFS:Mounted root (nfs filesystem) freeing unused ker...
21 years agocloud,
I use the Omni-nfs server v4.2 as the nfs server in windows2000.So I boot the system as nfs is successful.Are you correct the kernel config as Microtronix documents? Tony,Zhu
