21 years agowhat is the problem.......?
2004.11.09 16:12:41 (*) Building system_ram_contents.srec using "build"
# 2004.11.09 16:12:41 (*) cd F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1 ; nios-build --sdk_directory=F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1/nios_cpu_sdk -s -o system_ram_contents.srec -b 0 nios_cpu_sdk/src/main2.c nios_cpu_sdk/src/main2.c.o: In function `main': nios_cpu_sdk/src/main2.c.o(.text+0xa0): undefined reference to `mytimerISR' nios_cpu_sdk/src/main2.c.o(.text+0xa2): undefined reference to `mytimerISR' nios_cpu_sdk/src/main2.c.o(.text+0xa4): undefined reference to `mytimerISR' nios_cpu_sdk/src/main2.c.o(.text+0xa6): undefined reference to `mytimerISR' # ## nios-build error: last system call returned256 # ## (Perhaps you need ".global _start" and "start:") Died at - line 85.# # 2004.11.09 16:12:46 mk_custom_sdk: WARNING # # 256 cd F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1 ; nios-build --sdk_directory=F:/kdj/adtb2_cyclone/IF_single_flash/040927_3.1IF_single_4.1/nios_cpu_sdk -s -o system_ram_contents.srec -b 0 nios_cpu_sdk/src/main2.c # ERROR: Could not build Peripheral Contents for nios_cpu Error in processing. System NOT successfully generated. mytimerISR is the function name of timer interruption.it's contained in the program. # ## nios-build error: last system call returned256 what's the meaning?????? thx faint boy1 Reply
If possible can you give a code sample that uses the timer (and more info on the system itself).
If I don't get back to you soon just email me and I'll be a bit faster (email address is in my profile)
