16 years agoWhat is the difference between main() and alt_main()?
I write a very simple program, driving LED through PIO. Both function can work. If using main() , the code size is 1940 bytes. If alt_main(), the code size is 472 bytes. It seems that main() include ...
16 years agoHi sabertooth
I copy here the comment to alt_main() definition /* * alt_main is the C entry point for the HAL. It is called by the assembler * startup code in the processor specific crt0.S. It is responsible for: * completing the C runtime configuration; configuring all the * devices/filesystems/components in the system; and call the entry point for * the users application, i.e. main(). */ Regards
