21 years agoWhat cause this problem?
I modify the nios2 cpu and run the program that contains my own defined instruction on linux. After the execution, when I use the command "ls", the following problem will happen and the linux will be rebooted.
----------------------------------------------------------------------------------------------------------------------------- Buffer layer error at /cygdrive/f/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/fs/buffer.c:1262 This architecture does not implement dump_stack() attempt to access beyond end of device ----------------------------------------------------------------------------------------------------------------------------- does someone have ideas what cause this problem? thanks!4 Replies
Out of curiousity, what does your custom instruction do?
--- Quote Start --- originally posted by ken@Dec 16 2004, 03:22 PM out of curiousity, what does your custom instruction do? --- Quote End --- Oh, I use the instruction "call 0x600000*" to load a certain number of instructions from main memory into onchip memory. The added hardware component will interpret this instruction and load operation. Maybe the hardware change the state of the CPU and thus make the linux collapsed? Thanks! - Altera_Forum
That sounds like a distinct possibility... I'm not a low-level programming kinda guy so I couldn't say one way or the other.
Sorry I can't be of more help... - Altera_Forum
Okay, you just freaked me out. You've modified the Nios II CPU so that a call instruction to a special address causes data transfers between main memory and onchip memory?
Here's the way I would recommend doing this. Create a custom instruction that has an Avalon master interface. When you execute the custom instruction, have it perform the equivalent of a DMA operation and do the memory transfer. If you Nios II has a data cache and this data could have been in that cache, it needs to be flushed.
