20 years agoWeird Operation With Out PRINTF
Is anyone experiencing weird problems if you don't use any printf's in the main loop? I am having problems with using the DMA to transmit data using a UART. The UART transmits junk dat...
20 years agoWhat are you pointing the DMA's RADDRESS (read address) towards?
I don't think your issue has anything to do with whether you're using printf or not, as I've found that pointing RADDRESS at non stack-resident variables tends to work (global, statically declared variables, or malloc'ed buffers), whereas anything stack/function resident will return garbage. A simple check (to see if I'm correct) would be to add the 'static' qualifier to any of your stack-resident variables to see if that helps. Cheers, - slacker
