16 years agoWeird Ethernet problem
Premise: I don't know if this weird problem is related to TSE, sgdma or Nios code. Please help me to identify, or better, to solve it. I'm using Nios II with tse mac and National Semi DP83640 p...
16 years agoThank you for your answers Bill.
I definitely think it's a driver or cache problem as you suggested. If you have any other advice I'll be grateful, since I've been stuck on this point for a few days so far. This is my latest results: I'd exclude hw/fpga problems: I reduced Nios frequency,removed data cache,changed Quartus project fitting effort, timing constraints and clock distribution system but I always obtained exactly the same behaviour. I kept on testing with the problematic case: rx frame arriving 15us after sending the tx frame (both 60 bytes long, about 6us required for transmission) - tx frame period = 5ms: frames correctly transmitted for 510ms, then it doesn't work for 330ms, then again ok for 510ms and so on - tx frame period = 10ms: similar behaviour but ok/bad times are splitted 650/190 - tx frame period >= 25ms: ok Note that the period is always 840ms: why? Can this suggest the cause of the problem? Finally: remind that if tx and rx frames are almost overlapped on wire (<5us skew) or are very separated (>50us) the system works perfectly, whatever the frame rate is!!! Regarding the phy driver, I use Quartus 9.0sp2 and this actually supports only National DP83865 and DP83848C. My dev board came with a patch of altera_avalon_tse.c in order to support the DP83640 phy. I'll check this file for bugs Regards Cris
