16 years agoWeird Ethernet problem
Premise: I don't know if this weird problem is related to TSE, sgdma or Nios code. Please help me to identify, or better, to solve it. I'm using Nios II with tse mac and National Semi DP83640 p...
16 years ago --- Quote Start --- Thank you for your answer Bill. Where do I find this cache configuration? --- Quote End --- I meant to be sure to use non-cached addresses with SGDMA. With the Altera TSE and Interniche you don't need to worry about this. --- Quote Start --- I use a standard design provided with my dev board, with minor changes to fit my needs: - Nios II/f core - TSE MAC + sgdma rx/tx + on chip memory descriptor memory - Micrium RTOS II + Interniche stack --- Quote End --- This could be different in NIOS II 9.x but in 8.x the National Semi DP83640 is not listed in the supported PHY table. Do you have an alt_tse_phy_profile entry for it, or can you confirm the entry being used is identical to the DP83640? Just because this came to you as a kit and/or with drivers doesn't mean it's correct. Our development board (I think from the same company as yours) had a hardware design flaw, and the supplied TSE and PHY Altera drivers are NOT bug free. --- Quote Start --- The only reference to cache I could find is in Nios configuration in sopc builder. Should I disable it? --- Quote End --- No. Performance will be shot doing so. --- Quote Start --- Regarding your question about the driver, all mac and phy initialization is performed by OS and stack: that's why is said it was the standard one. --- Quote End --- Got it. Don't take that to mean it's bug-free. You could be doing something that is exposing a bug. Bill
