16 years agoWeird Ethernet problem
Premise: I don't know if this weird problem is related to TSE, sgdma or Nios code. Please help me to identify, or better, to solve it. I'm using Nios II with tse mac and National Semi DP83640 p...
16 years ago --- Quote Start --- How does it happen exactly? Is the rx_en signal suddenly de-asserted in the middle of a packet, or is it entirely de-asserted? --- Quote End --- When there's the problem rx_en is always low, it doesn't become de-asserted in the middle of packet. I also checked the rxerr signal from phy but it signals nothing. --- Quote Start --- Here are a few possible causes I could think of: - bad connection between the phy and the FPGA, or noise/coupling on some signals --- Quote End --- I use a off-the-shelf development board (DBC3C40), so I exclude connection problems. Moreover the board has two ethernet ports and both show exactly the same behaviour. --- Quote Start --- - the MAC and PHY are'nt using the same clock to communicate on the MII bus --- Quote End --- I tried several clock design: same clock for mac and phy, pll for clock regeneration, phase shifting them and so on, but so far I again obtained always the same behaviour. --- Quote Start --- - bad configuration of the PHY (MDIO registers) --- Quote End --- I used the standard configuration provided with the driver. Can you suggest me anything I can change? I read the phy datasheet but I couldn't find anything that can be related to my problem. --- Quote Start --- - power supply problems on the PHY (bad filtering and/or decoupling) --- Quote End --- I'd exclude for the former reason. Should I trust the board supplier or not? Regards.
