20 years agoweb server on niosII
hi, i,ve successfully run the web server program on nios II,and i've modified the ro_zipfs contents,then after building the program and running,and then typing http://ip (http://ip) addr,i get...
14 years agoHello,
I'm trying to modify the contents of the ro_zipfs.zip file and then program the flash. However, when i try to open the webpage i get the error 404 (Can't find the requested file file. Have you programmed the flash filing system into flash?) It seems that when im modifying the file, something wrong is happening and the file is not being downloaded on the flash :S any idea how to perform this correctly? Thank you in advance :)
