12 years agoweb server demo program using de2_115 kit
Hi
I am working on web server demo program and getting errors while building the project.The errors are shown below error: 'EXT_FLASH_BASE' undeclared (first use in this function) network_utilities.c web_server_rgmii_0 line 290 error: 'EXT_FLASH_NAME' undeclared (first use in this function) network_utilities.c web_server_rgmii_0 line 213 error: 'EXT_FLASH_NAME' undeclared (first use in this function) network_utilities.c web_server_rgmii_0 line 419 Please help me solving these errors . pramod,3 Replies
If you have a look at the network_utilities.c file you will find functions that give the kit's MAC address. By default when you create a web server demo application, the created functions in network_utilities.c expect to find a parallel flash called EXT_FLASH, and read the MAC address from there. It's possible that your kit uses a different flash, or a flash with a different name.
You should have some example applications that were delivered with your kit. You can copy the network_utilities.c file from those examples, or edit the file yourself so that it doesn't try to read from the flash but return a fixed MAC address instead. - Altera_Forum
Hi sir,
Thank you for the reply.I have been searching for the file network_utilities.c and I am unable to find it.If u have any references for that file please guide us through your reply. Pramod - Altera_Forum
The file network_utilities.c should be in your project with the other source files. It should even be in the file list in the IDE.
