20 years agoWatchdog has expired.
<<Watchdog has expired. Targed detached.>> I've often faced this problem when I try to debug some program, however I can't identify "who" is this watchdog. So I can't disable it. Someb...
20 years ago --- Quote Start --- originally posted by david_cai@Aug 2 2006, 08:28 AM today i encountered the same problem under the following operation:
i reset nios system by hardware when debugging, then niosii ide report the same problem...
maybe when your system broken when debugging then ide will report this issue.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17350)
--- quote end ---
--- Quote End --- Yes, your info made me remeber another spot. I discussed this error once with a mastership student and he told me that a possible reason to this is when the communication between some Nios CPU and the Nios IDE falls. It was exactly what happen with you, wasn't it? However may exist other reasons to this communication falls, such as when a Nios CPU, or the Avalon switch fabric, is so busy so that stops sending messages to jtag_debug_module. However I'm not being able to identify what component in the SOPC builder could be answerable for this. Mendonça.
